1 - 10 of 10 Posts
ok some im thinking of buying some heated leather seats to upgrade my truck but my question is since my truck is an XLT it doesnt have heated seats in it currently so how in the world could i get these heated seats to work. Do they run on constant power or is it interment power?
Needs more mod money
My Excursion has a constant (ign switched) power feed and there is a control module attached under the seat......I think you could do it .....if you get complete seats and run a fused ign power wire. Don't know the fuse size but I could look if you like
that would be cool then i would just have to figure out the switch cause did ford have multi settings on their heated seats or just on off?
what about aftermarket heated seats? I would think the wiring would be not to bad, but I would look into reliability.
They switches are on the side of the seat and are just on/off on mine
do you think you could get a pic of the plug under your seat. I wonder if my truck has it just under the carpet?
thanks i hope my truck is prewired but im not sure!!!
Here's the schematic for heat and power. I just put seats in mine this weekend from an Excursion and it only took me 10 minutes of Googling to find these. I was already wired for power, just not the heat.
Apparently heated seats wasn't an option in a 2000 truck, so the spots in the fuse box these pictures refer to for heat do not have connectors in them. I wired them up to another spot, and used inline fuse holders.
thanks i hope i can get this done should be nice
1 - 10 of 10 Posts
