1 - 7 of 7 Posts
The Original
Does anyone know where to buy a grey headliner and a black rubber floor for the OBS truck?:D
Time for some TLC:D
OBS Stroker
LMC has the rubber floor.
Just recover your old head liner board, I did mine. A good automotive interior shop should be able to get you material that matches dead on.
Early bird gets the worm
Broncograveyard.com for the flooring (cheapest I have found)... not sure about the headliner, but I bet they have it.
Do you have carpet or vinyl in now? I have carpet, but I am thinking of switching to vinyl soon.
Even with cuts in the board?
How bad are the cuts? If it is just sliced, it should be no problem. The foam covered headliner material will hide a lot of imperfections. I did mine. It will look a little lumpy at first, and you will think "What the heck have I done?", but then it will even out. Mine looks better now then it did when I took the pictures, after all the foam re-expanded.
1 - 7 of 7 Posts
