1 - 4 of 4 Posts
Hi I installed new led fogs and headlights. Now the fogs only work with highs not lows. Any way to fix this
Since the fog lights only work with low beams and shut off when the high beams are activated, my guess is he managed to switch the high and low beam plugs. I put led bulbs in my fogs and they worked as normal. I have also swapped to hid/led combo on the stock housing and everything stayed normal. I then swapped in new projector housings that use h1 bulbs in both high and low. When I did this swap, I wired up so both h/l stay on when highs are activated, everything works normal.
Sent from my Vivo XI PLUS using Tapatalk
1 - 4 of 4 Posts
