1 - 3 of 3 Posts
This started this morning and even has the mechanics confused.
With the lights and dash set to auto, if I turn on the left turn indicator the headlights turn off. The right side operates properly.
With the lights toggled to the manual settings, the headlights stay on when the left turn indicator.
I get to work and ask the mechanics if they have seen this before. My 2007 F350 6.0L stumped them. The Snap-On reader did not pull any error codes related to the lights. It did throw an error about my turbo which I'm aware of and have the replacement on the way. There was an error for my fan clutch as well but I knew that was going to occur when I converted to the 97 7.3L fan clutch when I replaced my water pump this past summer.
But wait there's more. On my way home with the lights to the manual position and the headlights staying on when the left turn indicator is on, my high beams will not turn on when the stalk is pushed forward. They will turn on when the stalk is pulled back for "flash to pass".
So with that said what should I be looking at to resolve this?
don't play well w others
New multifunction switch will cure all of that.
1 - 3 of 3 Posts
