1 - 6 of 6 Posts
1997 F-350 CCLB 7.Tree
Alright, so here is my issue maybe someone can offer some insight.
So I noticed my headlights where loose on my 97, this was because they needed to be adjusted, I adjusted them upwards and now they are tight and dont bounce around. The issue is I believe they are two high now but if I lower them with the adjustment again they become loose. Is there something Im missing? or is loose headlights just a thing for these trucks?
Side note: Everything including the housing is tight, its just the headlight it self.
You must have some broken clips or adjusters. They are not to tighten up the headlights, they should be tight no matter how they are pointed. The adjusters just allow you to aim the headlights correctly.
yea thats what I figured, so ill have to take apart headlights to see if I have something broken correct?
Sounds like the bulb isn't installed correctly if it's just the bulb and not the housing.
I fixed it it was the clips holing the adjustment
Cool
  • Like
Reactions: CA7.3
1 - 6 of 6 Posts
