1 - 9 of 9 Posts
sick 6.0
i had blown head gaskets on my truck when i took it appart the heads were not warpped but had pitting. has anybody had any luck getting the machined or whats the best option to do
I Just Break Stuff
Not gonna hurt to take a few thousanths off.
Word
The first thing before you machine anything off your head is to check the block to make sure it's COMPLETELY flat....if that checks out I don't take anymore than .005....if you can't true them up with that then it's up to you whether you go farther....and adding hardened seats will run you a pretty as well....that's just my $.02
Word
wouldn't it be better to measure the protrusion of the piston before determining how much is acceptable to remove from the head?
That's why I said check the block first...if it's ok then you still have the stock tolerance on the bottom end and can move on to the heads....
1 - 9 of 9 Posts
