1 - 6 of 6 Posts
well after reaserching and getting positive feedback on rev-x i was more than enthused to try it to fix my sticky problem....needless to say it didn't truck still runs like crap when its' cold and the only thing that has improved startup was changing my glowplugs....just wondering why it works for so many and it didn't for me? thanks not trying to be a downer but would like results
Mike
Check your FICM voltage at start up, there are links here to tell you how. If it's below 45volts send it to ED at FICMrepair.com. I did and they were fast. I also got the Atlas 40 tune loaded into it and it does make a diffrence.
Hope that helps!
Thank you for trying our products. But I would like to say that if you have an oiling problem we can almost 100% cure the issue. But there are other problems that can cause this issue, and make it look like a sticky injector. I would get your FICM checked out like Springnook has stated. I hear about this all the time. Please don't count our products out, you have the most protective additive in your engine that you can buy! Once you get your hard parts working correctly, you will start to see the differences that REV-X Oil additive can make.
hate to say it but it didn't fix it...i just put new injectors in and it runs like a top...sticky injectors was the problem...
Thanks Rev-X, you guys don't know how happy I am. My truck was missing so bad that I was desperately looking for new injectors, then after reading about this "Rev-X" product, I decided to give it a shot. To my amazement it worked! My truck hasnt missed a beat since Saturday afternoon when I put it in.
I went on their site and found a dealer (alsip auto and collision in IL) local to me and went and picked it up that same afternoon.
1 - 6 of 6 Posts
