1 - 6 of 6 Posts
The truck turns over alot before it starts now. I changed injectors to a stage 2 and a t-500 hpop. I didn't have the chip reburnt yet. will that cause thr hard start
You have air in the high pressure oil system and until you get that air out you will have hard starting. If the truck is driveable you need to take it out and run it for at least a half hour or take a 30 mile drive and it should be ok.
get on it to push the air out of the heads. ")
Stock tuning won't cause that hard start with stage 2s..I,ve been waiting for my reburn for a month now with stage 2s ,Starts fine. Air in the system like said above, drive it
Maybe you have a 94/95 front cover and your hpop res is bleeding down.
1 - 6 of 6 Posts
