1 - 6 of 6 Posts
If I leave it for 12 to 24hours its fine but if I go 2 to 3 days it misses and pops and smokes big black clouds and has no throttle response. Finally it will clear out and be fine but it takes a few mins.
I know its getting to much fuel but how do I determine if its a oil or fuel problem
Any thoughts?
Perhaps glow plugs and/or HPOP draining down too much?
New glow plugs 4 months ago, when I did the injectors and there are no codes at all. I like your thought on the HPOP cause then I could upgrade and it might help explain why I didn't see any milage increase from going to the single shots:(
There is a plug on the top of the reservoir. Run it and then shut it down and immediately check the level of the oil with a homemade dipstick. Check it next day and the next day evening and the day after that. See if the level falls.
Would the oil level go up or down? That would tell me if the hpop was backflowing correct?
If it leaks, the level should go down.
1 - 6 of 6 Posts
