1 - 20 of 36 Posts
I just bought a 05 6.0. when i test drove the truck it was warm. since then i noticed that when i just start up it shifts hard and runs the rpm's up higher for the first few times through the gears. After that is shifts smooth as can be. Any one have any opinion on this?
jjmills
I
Guest
jjmills
If you jump in, start it and drive away I would say it's normal. 6'0's like to warm up before being driven.
I
Guest
IDK, The two 6.0's I have owned don't shift all that well unless I let the temp come up a bit.
Captain Negativity!
2nd is over drive coming on with forward. Mine is firm. But thats in the tune...
Thanks for the input. I just wasn't sure if this was common with these motor/trany combos
jjmills
Scab
Ok let me thread jack.
Mine has a noticeable clunk in the 2-3 upshift and it's done it for the last 60k miles. Is this something anyone has seen before or specific to my truck?
I
Guest
Probably your specific truck.
Scab
I didn't know if there might be a TSB out there somewhere
I
Guest
Intermittent Clunk from TorqShift Transmission:
Trucks equiped with the TorqShift may exhibit a clunk when shifting from drive or reverse to park, from reverse to drive, and/or at the 2-3 upshift. If these conditions are intermittent, it is normal play/backlash in the drivetrain. Broadcast Message 7028, 0215.
Scab
Well ok that's good I guess. I just wonder why I only get it on that shift.
I
Guest
How many miles on your truck? Did you ever flush the trans? I know you said it has allways done it but maybe the filter was no good to begin with..
Scab
82k on the truck. It has had multiple trans services. I am thinking that something is just set up a little loose.
I was hoping that there was some snake oil I could put in there and make it all better
I
Guest
Is your truck tuned?
Scab
Yeah Innovative
Scab
Well it seems to do it with any tuning, but it is more pronounced with aggressive tuning.
1 - 20 of 36 Posts
