1 - 19 of 19 Posts
· AllYourBaseAreBelongToUs
42 would be awesome with mini-mes. A 45 is a little too much for a daily driver even with b-codes. Doesn't really lite 'til around 2200rpm. It is a lot of fun once it does though. :D
42 spools like nobody's business. I think David said there's even a couple of people using them with stock injectors. I'm putting a 42 back on asap.
· Registered
A lot of it is going to depend on the size of the 42R your looking at. A 4202 is not going to spool well but with a proper sized exhaust housing once it lights hang on. If your planing to street drive most of the time a 40 would be a better choice but you will give up a little on the top.
· Banned
Yeah, the 42 is an especially varied turbo based on the compressor wheel you choose. Within the 42 model there is one model with a 96lb compressor wheel. On the other hand there's also one that barely moves 80lbs.
The 42 line is wildly varied depending on the exact model.
· Cummins Power
Lotts a wanna be :nutswinger: call II and get a K31.
· Registered
And that costs??????????????
· Registered
I went with the GT4294 with a 1.01 a/r turbine housing. The truck is a big dually used as a daily driver and for towing. Injectors are 200cc splitshots. I imagine it will spool really quick for my use. The 1.01 housing may be too small, but I will be measuring the backpressure, so a larger housing will be used if needed. These turbos are not cheap, I got mine for $1799.00.........sorry can't say where. I tried to get it through David Lott, but he said he could not match the price. I have MANY hours in my custom mount and piping, so if you can't do fab work, by all means buy Davids complete set-up, its well worth it.
· Registered
:nopics:
· Registered
I'll take a few, can't give up all my secrets.;) I took some pics, but there are too large and have no way to downsize them..........the new software is no loaded yet. I can email them to someone if they can downsize them and post them.
· Registered
Simple way is to email them to yourself then click make smaller when the pop up box pops up. Windows will automatically resize them.
· Registered
The set up is going out next week for the hot pipes with bellows. The base plate and stand is aluminum. The fittings are all straight thread o-ring, -4 feed and -10 drain. Once its all done I will add what it would cost to duplicate. I still need to fab up the intake y. Thank you for the compliments.:D
· Registered
Discussion Starter · #18 ·
Please keep us posted...I may try to follow in you foot steps and DIY my own kit.
1 - 19 of 19 Posts
