1 - 12 of 12 Posts
The Sound Of Madness
Im looking for a hide-a-ball style hitch for my my 99 SD. When i bought the truck i installed a set of firestone air bags and i cant find a hitch that will work with the bags. I talked to B&W and they said i should have bought a hitch first then ordered air bags that work around the hitch. I dont want to buy another set of air bags, does anyone know were i could look for a hitch That would work or have any other ideas?
build one?
PSN Pretender
Probably be easier to sell your current bags, or find out if you can get just the mounting kit for GN hitch style bags.
My early 99 had firestone air bags on it when I bought it. I put a Drop-N-Lock hitch in my truck and had to space the air bag brackets out about 3/8" from the frame to make it work. That was 5 yrs ago and I haven't had any problems. Good luck!
Custom Trailer Sales
:whs: That's probably your best bet unless you want to fabricate your own hitch.
Building Farmboy Monster
Ya I would do what he said. I put fire stone air bags on a truck with a bw, you may have to cut a small tab off of hitch to get the air bag brackets in the right spot. Really the only part that sucks is drilling threw all that steel, good luck
Discussion Starter · #8 ·
Thanks for the tips! Ill see what i can do!
I am having the same problem, went to have a b&w installed today, and they couldn't because of my air lift airbags. I guess the older model b&w that was for the 99-05 superduties worked fine. They have switched to a newer model that fits all superduties 99-10, although now it doesn't work with side mounted airbags. This sucks, really want the hitch. Any luck with this?
look on ebay for model 1105R, it fit 99-04. and works better with airbags. its what i did. they are probably getting scarce out there now though.
Discussion Starter · #11 ·
ill check, who makes the model 1105R?
It is still a B&W turn-over-ball. Just the model that covered only 99-04 or maybe 05
1 - 12 of 12 Posts
