1 - 10 of 10 Posts
alright summers coming up and im starting a parts list for my truck, im looking for a hot running OBS that'll keep up with some of the Cummins guys around here, including my brother:swordfight:
so let me know what you think:
H2e (modded if i have the money)
200cc hybrids
intercooler(already have parts)
fuel system(ready for install)
Valair clutch
beans reburn
im thinkin thats right around $5000
i was hoping to save money and run this with my stock HPOP for now...
what about headstuds?
thanks:ford:
OverFuelingForYourPlesure
do head studs and valve springs, if you can find a good deal on a 17 degree hpop put it in there but you may be able to get by with out it.
what nozzles are you looking at with the injectors?
probably gonna start off with 30% so i could slip by without studs and springs, but if i can get them ill go bigger
I'd get injectors from Nate and tunes from Matt.
Those 2 are GOOD together.
Beans is great too though!
yeah ive heard good things about both of them, but ive been looking at rosewood because of the price
Gona have a hard time keeping up with a less powerfull truck with a Auto..so your need to have lots more HP.
yeah i know, but id much rather spend $1000 on a good clutch than $4000 on a built auto tranny
i don't need to beat em on the track all the time, im gonna be doing a little bit of sled pulling as well
if your going to be pulling better look at double disk clutches
Discussion Starter #9
It wouldnt be very often maybe 2-3 times a year, would that still tear up a single disk?
the valair ceramic if it gets hot from slipping is done it turns basically into a a plateLOL. call valair though iirc theyll make you a double disc for your application, i know theres some proto. double discs of theres out there so far with good results. nozzles all depends on what you wanna do with the truck call swamps or beans and theyll fill you in. tuning is your choice but i hear beans and swamps are awesome. i would do headstuds for piece of mind and valve springs iirc are a must over 40 or 45 psi.
1 - 10 of 10 Posts
