1 - 11 of 11 Posts
im lookin at getting some glowshift gauges and i wanted to hear yalls input on them.
are they good quality and stuff like that
Had em. Boost was accuarte but a little slow compared to my Snow Performance digital but I liked it. The Tranny seemed to be alrite, but EGT was constantly off in the higher range by 200-400 degrees. Said 1,400 degrees pulling my boat at 65mph on flat land and stock settings and injectors. My buddys had the same luck.
Old Yeller, REBORN
All comments I have seen about Glowshift are not good.
Hood Rich
with comparing my temps with other trucks, mine seem to be off. I used to stand behind them, but when it came down to verifying them for accuracys... id say save up for better.
Intelligent Burro
Had the black face 3-1 gauge for a while. when the sun was shining the gauge was too dark to read. Then it started being a crap shoot whether or not it would work. I checked all my connections several times, sometimes it worked, sometimes not. All connections were soldered and heat shrinked from day one.
Finally gave up and bought Autometers.
'Merica!
I have Boost,Trans and EGT as well and they've worked great for almost 2 years now. The boost guage is starting to stick at around 5psi when I come off of throttle now, but i just flick it and it resets to zero. Mine are white faced and personally think they look way better/cleaner than isspro's or autometers. Just my 2 cents though.
1 - 11 of 11 Posts
