1 - 8 of 8 Posts
Premium Member
ZD-1 is pre 87, ZD-9 is 87-94
ZD-1 uses a spade terminal, and ZD-9 uses a bullet terminal.
either way, i use crimp connectors from napa to connect the wire to the glow plug.
Premium Member
motorcraft/beru only. autolites, champions, wellmans and bosch suck, and are a waste of money. they cost on average $5 more than the motorcraft/beru plugs too
you can buy the correct glow plugs from rockauto online for $9.83 each for the ZD-1's and $9.86 each for the ZD-9's
here are links for the glow plugs.
ZD-1:
http://www.rockauto.com/catalog/raframecatalog.php?catalog=48&partnum=ZD1A&a=FR48-ZD1A-240502
and for the ZD-9:
psn browser
Discussion Starter · #8 ·
Drove over to oriellys got motor craft with BERU stamped on them for $11.49. Autolights were 10.24. They had some electrical ends that worked perfect. Thanks for all the info guys. The oriellys part number for the glow plugs is MOT ZD9 for anyone searching local.
1 - 8 of 8 Posts
