1 - 3 of 3 Posts
STILL LEARNING
While I have the valve cove off to do the injectors I am checking the GP system since the truck started hard.
I used my ohm meter to check
-the VC gasket plug and I am getting .7 ohms
-The UVCH and getting .7 ohms from the VC gasket plug to the injector plug and GP plug.
-The GPs are ohming out to 1.2-1.1 and one is open
Are these acceptable readings, other than the one open?
Yes they are. On my factory CD it says that they should be between 0.6 ohms and 6 ohms to be good but a lot consider anything over 2 ohms as being bad. When I checked a brand new ZD-11 it ohmed out at 0.6 ohms.
STILL LEARNING
Ok. thanks.
Drivers side complete. Now on to the passenger side
1 - 3 of 3 Posts
