1 - 2 of 2 Posts
Anyone have a trick to get to the third door hinge bolt on the upper hinge? I cant get to it with the extension and wobble socket I am using for the two bolts closest to the fender
don't play well w others
I usually pop the fender back side off
2 bolts inside under hood, 1 in between hinges, 1 on bottom, you can pull it out enough to get in there. Be careful, don't bend it
1 - 2 of 2 Posts
