Do all super duties have gem modules? I have a 2003 f350 cc 4x4 with 7.3. where is it located ? thanks
He's always fair...plus I live 10 mins from them so I always use them for stuff.Brittain @ Sunrise has gotten me a bunch of parts for about 50% of what my local dealers quoted.
No affiliation just a happy customer.
:ford:
get back to gd.com, lmao!! Hey Rich, that thing will be rebuilt before you know it!!!Can you post a pic of its location in your truck please? I am going to order mine today.
Not sure if your talking to me but here are a couple pics from my 02 sorry for crappy pics. Drop glove box and it is mounted in the upper right it 3 connectors going to mine and only 1 screw which takes some work to get out its towards front of truck. The first pic you can barely see the barcode the 2nd is a different angle.Can you post a pic of its location in your truck please? I am going to order mine today.
Dang brother...I love this truck. It's got more bugs than my duramax had, but it's a lot better looking for sureget back to gd.com, lmao!! Hey Rich, that thing will be rebuilt before you know it!!!
Were you the same Richierich from Hotboat/Performance boats also?Dang brother...I love this truck. It's got more bugs than my duramax had, but it's a lot better looking for sure
Do you have any Glamis trips planned this year?
I am new here and trying to troubleshoot my husband's truck. I have more time on my hands I guess than he does. Maybe I should have started a new post but his reply was kind of what the problem is all about. 4x4 is not working on our 2002 F250 7.3L and there is no light on the dash switch, key fob doesn't work, put key in to unlock door and alarm goes off, radio stays on, there has been times the windows wouldn't work in the heat of the summer and the dome light was staying on after starting for about 15 minutes. From reading info on other sites (didn't find yours til now) he had swapped the relays and checked the fuses. After swapping the relays the dome light now works as it should. He also took to a friend of his brothers who is a mechanic and ex ford tech. He tested everything & ran diagnostics and thinks the problem is a wire somewhere. He did find a corroded wire in the instrument cluster and replaced it but it didn't fix anything. He said he could not test the gem/4x4 control module though. We had read numerous posts stating on the 2002 f250 4x4 7.3L they had replaced their gem and fixed some of these 4x4 and electrical problems. The part number behind the dash on my husband's truck is YL34-14B205-BA and is referred to as a GEM/4x4 shift control. The replacement part we purchased is 3C3Z-14B205-AA. The mechanic and a tech from Ford that I called stated that the module is just a 4x4 control module and doesn't control anything else. He plugged it in and didn't program it and said it did not fix the 4x4. Any thoughts on something I read that stated "in 2002 the GEM was no longer used and it's functions were split up by three separate modules: the instrument cluster (IC) the vehicle security module (VSM) and in 4X4 equipped truck, the 4X4 module.."They stopped mounting the vsm/gem behind the fuse box in late 01 due to the water problems shortening them out. The 4x4 along with the windows, power door locks, and everything else it controls is all in one box.
You are correct, on the 02 that module behind the glove box is the 4X4 control module. According to the FSM a replacement must be configured by Ford in order to work.I also have been chasing down a non-working 4X4 issue for two years now. Everything in my 2002 F250 7.3 auto works except the ESOF. Everybody keeps saying that the "box" above the glovebox controls windows, lights, radio, ect,ect,ect BUT my "box" has been completely removed from my truck for over two years and everything else works. If all of these electronic things are controlled throughout this "box" then how is all of my stuff still working perfectly when my "box" has been unplugged for years.
I was told this is called the 4X4 shift control module OR the chassis control module. My part number is 2C3T-14B205-AA and was removed from directly above the glovebox. I have tried two different used ones from wrecked truck to no avail.
I wish I could get the 100% true real story on what would fix my ESOF without spending an arm and a leg at the stealership but with so much misleading information it's hard to figure out just what I need to fix my problem.
I would really like to install that 3 way switch mod I read on here a while ago but the guy that originally posted the mod disappeared before explaining exactly how he did the switch.
Does anybody else have any ideas that would get my ESOF working again?
Thanks in advance.
