1 - 8 of 8 Posts
I have a 2004 6.0 stock. A couple days ago I was driving along, when suddenly my radio went out. I looked and all my gauges had "pegged" as if I had turned the ignition off. The battery light also came on. I did not lose any powere to the engine. Headlight and wipers still worked. Any ideas???
Your alternator is toast...Had the same thing happen to my old 04...Your running on strictly battery power now..Your batteries will die a quick death and at same time ,you're damaging your FICm and injectors..
:whs:
Do not drive the truck until you have the alternator tested/replaced, i would also use a trickle charger and juice those batteries back up to full power!!!
One of a kind
x2
burning mine saving yours
x3, same thing happened to me and my gauge cluster. I trickle charged both batteries overnight and the following day replaced my alternator. Problem fixed. I knew if I pushed it ficm can die, and then it gets $$$$$.
1 - 8 of 8 Posts
