1 - 16 of 16 Posts
Oooo, White Lightning !
Well, while installing my trans temp I tore my boost line.....Its a mechanical gauge, but it comes with a little crush sleeve for each end a brass one.....Where can I buy one....What is the actually name for it ???
<<< THE GAUGE WHORE...
Its a 1/8 compression fitting... Most times you can pull it off and reuse it, but if not any GOOD plumbing supply place or hydraulic fitting place should have the parts...
Compression ferrel is the "real" name for it...
Thanks.......You should write a sticky post on gauges LOL.
All done now
I think you can even get them at Home Depot or Lowes. Look in the plumbing fittings by where the stuff to hook up ice maker hardware is.
90% of the depots only have 1/4 but you could check...;)
any good auto parts store should have them in there gauge section
Discussion Starter #9
Alright........Thanks guys.
I bought a 4 piller mount........So what y'all think I should put in the 4th hole
Pyro #2
Fuel pressure
Oil Pressure
Oil Temp
Any other ideas welcome.
All done now
Oops, thought you said 1/4, no you can't get them there. Sorry. Need to get me some gauges.
Fuel pressure is the most important after the big three
Ya thats what I was leaning towards
Hey if you ever are in need of the ferrel again aka crush sleeve, most truck stops and dealers carry a full range of the air and fluid fittings. And yeah put in a good quality fuel pressure guage, that is the one guage you dont want to cheap out on, it's like a heart monitor for your truck.
Discussion Starter #15
Ok thanks
Another Canuck eh........Where abouts in Alberta you located ???
1 - 16 of 16 Posts
