1 - 13 of 13 Posts
We have 10 of these available, $1099 shipped to your door (lower 48 states only).
BUY ONLINE
Garrett PowerMax Turbo 2003 6.0L 777469-5001s
2003 F-Series & Excursion Power Stroke Diesel
- Model years 2003 (PN 777469-5001s), 2004-2007 (PN 772441-5001s) 6.0L Power Stroke engine
- GT3788VA Turbo
- Features the Garrett® patented Advanced Variable Nozzle Turbine (AVNT) design for increased compressor flow and boost response
- Utilizes nine movable vanes which significantly increase turbine efficiency and improve engine performance from idle launch through peak torque
- Patented integral electro-hydraulic actuation and proportional solenoid for infinitely variable control
- Larger compressor wheel over stock increases maximum power range while keeping turbo speeds down for the same power output
- Supports up to an additional 175 HP over stock with no sacrifice in drivability
- Suitable as a performance upgrade or replacement for original equipment
- Outline interchangeable for a perfect fit each and every time
How much more efficient are these compared to the stock one?
I'm looking to pick up a turbo and a mild injector to increase fuel consumption....
rollin coal!
will this thing sound like a stock 03 turbo??
I used to have the MAP for this turbo, but I lost it somewhere. It is quite a bit more efficient than stock handling 175 HP over stock.
rollin coal!
How would this turbo do towing?? Looking at a set of 155cc injectors to go with it
This turbo will work great for towing.
We still have plenty of the 2003 turbos ready to ship, let me know if you want one.
rollin coal!
Is this price still good???
Even with the bigger injectors? Just wondering cause we have a 62/70 non vgt Phat Shaft on there now and we aren't real happy with the way it performs.
1 - 13 of 13 Posts
