1 - 9 of 9 Posts
So I was an IDIOT and didnt D/C my batt calbes when puttin in my CPR fuel system and i accidently hit a wrench on the GPR and BZZZZZZZZZ i pooped my pants and now glow plugs no worky. dummy manual talks of 2 14ga links on the starter solenoid. I cant tell which wires are them, and can I wire a fuse in instead?
anyone got and pics & tips?
PSN Pretender
Just locate the fuse links on the solenoid and give each a tug. If the wire stretches then the link is bad.
links were good, relay was bad. replaced with a starter relay and it wont turn off now. energizes at startup and stays on!!
any clues?!?!
any clues?!?!
A starter relay will not work since it is case grounded and you need a case isolated one. The relay gets its ground from the PCM so it does not need to be grounded to work.
so when it closes it takes the case ground and thats why it dont open back up again?
if i isolate it on the bracket will it work?
OEM Moderator
Just put the right relay in the glowplug or a Stancore.
1 - 9 of 9 Posts
