1 - 6 of 6 Posts
· ΜΟΛΩΝ ΛΑΒ&
Where can I get braided stainless fuel line, line for back around the turbo and down pipe? Noticed one of my lines has a hole wore into it. Thanks for any info. Also what is everyone else using for the lines comming out of the back of the heads? Pictures are welcome. Thanks again
· OEM Moderator
I used stainless steel tube bent with AN flare fittings, then short sections of push lock Aeroquipe hose to mate to a Y-block. Photos are in the sig and the top thread of this forum.
Tom
· PSN nerd
i found mine at a local hydraulic shop just gotta make sure the hose is up for the heat rating. the stuff i found was good up to 450deg and 4000psi. i used some ceramic slide over heat shield on them too, that i found was for a welding/ plasma torch cable shield got it at a welding supply
· ΜΟΛΩΝ ΛΑΒ&
Discussion Starter · #5 ·
Thanks guys, I've been on summit looking. Thanks for the size geoff, -6 AN.
· Registered
No prob! I ran -6 everywhere. Some guys like to run bigger for supply line but honestly I have yet to see and pressure drop as of yet. And if you are running through the 1/8" NPT ports where the stock fuel lines go in I don't think you are going to need anything larger than that anyway.
1 - 6 of 6 Posts
