I had the same issue a few yrs ago with my front tank float, the brass had cracked. I drilled a little hole at each end of the crack , drained the fuel and washed it several times with degreaser then soap and water. Soldered the crack and put the float back. Worked great for a couple more months until it cracked again in a different spot. $14 at my dealer got me a package with two new floats and no more problems.The sender assembly is fine, but the float is about 1/2 full with fuel. No wonder it wouldn't float...lol Seems a little dangerous to try to solder it anymore.. options?
bought box bolts? yes.... I still cant sit down. :doh: At least these will easily come back off when I want to remove the bed again.You didn't?!?!?!!?!
Just make sure you anti seize the crap out of thembought box bolts? yes.... I still cant sit down. :doh: At least these will easily come back off when I want to remove the bed again.
