1 - 5 of 5 Posts
I am going to replace my fuel pump soon, Im thinking the weep hole is leaking. Wondering if there is any other maintenance I can do while in the valley, other than new lines and cleaning the fuel filter housing. Also on the front of my filter housing there is a fuel line connected with crimps. If i cut this line is there barbed fittings there that I can put a new line on it?
Go ahead and pull the turbo and replace the o-rings and remove the EBPV.
Drive it like ya stole it
If you've got the cash, an electric fuel system would be advised. Truck fires faster and runs smoother :) If not, suggest completely cleaning that fuel bowl as well as replacing the o-rings. No idea on those crimp fittings, sorry.
replace all 3 fuel hoese to the filter 2 are 3/8 1 is 5/16 be sure to get deisel reated hose.also check the banjo line at the heads there a re rubbers that go on there under the nuts. clean the screen in the regulator.
if your not good about draining your fuel bowl, be ready for what you find!
1 - 5 of 5 Posts
