1 - 10 of 10 Posts
Getting all the parts together to finish my fuel system. What size fitting is needed to screw in the fuel pump. Its metric to JIC isn't it?
Dead Member
Are you using the OEM pump or a aftermaket pump...?
A Ghost these days...
OEM SD Pump is 10mm X 1.0. A 1/8" NPT will work if your in a bind.
For the OE. Getting all the filters together to go underneath. Thanks guys.
What filter bases did you end up purchasing?
I just bought another Baldwin FB1311 and the damn inlet/outlet ports are 7/8-14 UNF. Kinda hard to find a fitting for. Im gonna try a -10AN union in it. Fits pretty good.
The Fireman
I just got a filter and base at Napa
Wix Numbers
24770 Fuel Filter Base
33528 2 micron Fuel Filter
Napa Numbers
FIL 4770 Fuel Filter Base
FIL 3528 2 micron Fuel Filter
Takes 1/2 MNPT for inlet and outlet
Wix Numbers
Napa Numbers
4770's are backordered and will not be available for at least a month, but no one can give me a concrete answer of when they will have them.
Wix 24770 & Napa 4770 Base - BACKORDERED!: FleetFilter Secure Online Store
I resorted to the Baldwin base cause it has the 1-14 filter threads.
Dead Member
The Fireman
1 - 10 of 10 Posts
