1 - 5 of 5 Posts
I'm having some fuel delivery problems, been reading alot of posts and seen some similar symptoms but thought I'd ask around.
Truck started rough after work, made it 2 of the 3 miles home and it died. acted like it had run out of fuel. I knew I had about 1/2 a tank so I looked into things, found a blown fuse, identified a worn wire that had shorted out. replaced the wire and the fuse, problem solved. 2 days later, same symptom. No blown fuse. Though that I might have damaged the pump, but tested it and got 58lbs. Replaced the in-tank filters and the filter in the fuel bowl. Ran good for 2 days and died again. When it dies, if I release the pressure in the fuel bowl by opening the drain valve for a second, and then turn the key to on, let it charge up it will start and get me 2 miles to home or so, but then its choking again.
I'm thinking CPS or the ICP could be bad. any thoughts?
Banned
have you ran the truck with icp sensor unplugged?
I tried that with no noticeable differences. I ended up replacing it as well as the CPS. I'm still getting the same results. Kinda worried about Injectors etc. My neighbor is a mechanic and I don't know if he just wants business but he walked over and we talked about it. He thinks it needs new injectors, but I'm not going to dump a couple grand because he thinks that's what it is.
Banned
What type of icp data are you logging?
1 - 5 of 5 Posts
