1 - 9 of 9 Posts
Ticking time bomb
what should i have my fuel pressure set at with my setup. my setup is in my sig its at about 60 psi now
A Ghost these days...
That's about what im running mine at...
Yes..
So should I leave it at 60?
Does your fuel pressure fluctuate with the Fuelab pump. I have it set @ 65psi, but it ranges from 60 - 70psi depending on when I look at it.
I only have the mechanical gauge under hood. Seems like when I start the truck, fuel pressure is about 60psi. When the truck has been driven alot, pressure is around 60-70. IDK???
Hater Club
60psi is good. Anything above 70psi, my truck seems to take longer to start.
I dropped mine down to 55psi and I picked up a few HP on the dyno. Not sure why.
owner/president
I run mine at 68-70psi.Works good for me.
<<< THE GAUGE WHORE...
Stock injectors I ran 70-72, stage 2's were at about 65 and hybrids at 60...
Every truck, every injector is differant.
Ticking time bomb
Discussion Starter · #9 ·
No it doesn't fluctuate that I have noticed
1 - 9 of 9 Posts
