1 - 5 of 5 Posts
I have a fuel leak at the hard line fittings going from the banjo bolt to the back of the heads. Do you need to remove the turbo to get to these?
Thanks..........
It says you have a 3" DP in your sig. For me the passengers side I was able to get the down pipe out of the way and get to the fitting. And the drivers side I haven't done but has a fitting that moves the connection to what looks like an accessible place. Assuming the leak is at the head connection since the viton sleeves do get soft over time.
STILL LEARNING
It is a 30 min project to pull the turbo. Then you can easily access the line and replace the seals without bending them or the chance of cross threading them
I would pull the turbo, and replace the lift pump, the banjo bolt o-rings, and the seals at the head fittings, and the rubber hoses if it where me, just to prevent having to do this again in 10-15k, but i am ocd about that kind of stuff.
1 - 5 of 5 Posts
