1 - 5 of 5 Posts
Mean Green
Never was good at tracing a fuel leak. My truck is leaking fuel from the front of the motor its a slow leak and I can't really tell where its coming from. Looks like more towards the drivers side an it leaks down on the axle. I dunno where too start
09 6.4
i would look on the secondary fuel filter. the case that covers the fuel pressure regulator spring has a rubber oring around the edge of it and is prone to leak...i would start there...clean the area off with ether and see if you can see it running or dripping
good luck
mine was coming from the fuel pressure regulator on the secondary fuel filter. 4 T bolts and i changed it. kind if tight to get to..but i got it.
1 - 5 of 5 Posts
