1 - 3 of 3 Posts
i have a 96 powerstroke and i have a fuel leak on the engine that leaks into the valley and out the back drain hole. its not a huge leak but leaves a puddle in the valley after a few minutes. it looks like its coming from under the turbo pedistal . what else could leak besides pump and filter housing.
the pump is best guess leaking at weep hole but you have those small fuel hoses with clamps down there too
Also there is a rather large banjo bolt down there, I have seen the gasket fall out and leak.
1 - 3 of 3 Posts
