1 - 5 of 5 Posts
Seem like I have a slight miss idleing and there look like a puddle of fuel in the valley so I cleaned it ou8t and now it looks like it may be wet again but I smell fuel.
I know it has nothing to do with the chip, but it didnt seem to make much of a difference so im just wondering if I have another problem.
and I cant get a gauge on the fuel housing to check p[ress
GoNavy!
Re: installed chip seems like fuel is leaking
It is most likey your fuel drain o rings ...or possibly fuel line sleeves.... You can get some Here
Shortbus driver
The fuel heater pass-thru and WIF sensor leak on my fuel bowl.
I'm preparing for a bowl delete soon...
clean it up and put down some baby powder then look for the leak . could be the sensor on the side of the bowl, 0-rings on the bowl regulator, drain o-rings fuel lines or fuel pump. fuel pump has a small weep hole on the pass side I would check the secsor and pump first.
1 - 5 of 5 Posts
