1 - 14 of 14 Posts
Ok so I got the ITP regulated return w/ bowl delete and I installed it last weekend. I had a few leaks that have all been addressed and fixed with one exception. The rear passenger side fitting is leaking still. I have had the fitting out at least 3 or 4 times now trying to get it to stop and have double wrapped it with yellow teflon tape AND permatex thread sealer.. It is still leaking and I have no idea what to do next or how to get it to stop.. I have snugged it up pretty tight but am afraid to "reef" on it and crack the head.
I can see the fitting with an inspection mirror and it is definitely leaking where the fitting screws in the rear port.
Any ideas?
< pissed off pumkin.
I hated that one too, I had the same problem with the DI kit. I just got brave and put one more turn on it and it stoped seeping. I would worry more about braking the fitting off then cracking the head.
Dan
Dan
Yep that is what mine is doing.. Just seeping enough to make a small puddle under the truck..
u have cranked down enuf on it, i would tighten one more time, if it continues, then i would repalce the fitting, maybe the fitting is damaged?
Stupid Kid
Replace the fitting and that should cure your problem. If I ever have mine out for any reason I always replace the fitting with a new one.
At this point I am willing to try anything!
I am gonna try some Rectorseal 5 and see if that works too.
OEM Moderator
I can recall of two posters that cracked the head by putting to much torque on that fitting. I would throw a new on in there before I went bionic on it.
Tom
Try a new fitting. I had one fitting on the fuel filter housing that would not seal no matter what I did. I put in new one and it quit leaking. Somtimes the fittings look just fine, but won't seal due to a flaw that can't be seen.
Are you sure it is the fitting at the head port. I had problems with the tube connector to the JIC side of the adapter on that side. I ended up cranking it down and it went away. On the driver side I could not get the fitting to stop leaking at the tube no matter how much I cranked it down. Dennis sent me a new tube and it solved it. I to was very scared of cracking the head. If you still have the plugs/check valves that were in there originally take a look at how far they were in there. If you arent going any deeper than taht you should have nothing to worry about. I used Loctite 545 at the suggestion of FN74 and it worked fine on that fitting and on the drivers side I have regular teflon tape with 2 wraps and no problems because I did not want to wait for the loctite to dry. Be sure to get all the fuel out if you are going to use loctite. Good luck.
Yeah I'm sure its coming from the head. With the system pressurized, I can look with a mirror and see it weeping. I just pulled it out again and noticed my yellow teflon tape got bunched up and wasn't on the treads so thats my problem there. I scrapped the teflon and put on some pipe dope called "rectorseal 5" that I saw some were using.. I'm gonna let it setup overnight and hope that takes care of it.. If not, I'll try a new fitting tommorrow.
I have noticed in ym line of work, if u use too much teflon tape, it will bunch up like u saw and will leak. As a general rule in the air force when we use it, we tell our troops to put no more than a full loop[ and a half of the tape on the threads.
All done now
Just enough to hold itself in place. Same place I learned that.
Well the Rectorseal 5 didn't work either.. Fitting still seeping.. I'm getting close to using my Glock .45 :mad:
A diesel mechanic I talked with today gave me a tube of green loctite and said to try that.. Hell I'm about to use JB Weld :doh:
Village Idiot
try a new fitting..if you can aquire one ..
hope your drive way isn't blacktop..if so you may want to slide a catch board there.
1 - 14 of 14 Posts
