1 - 8 of 8 Posts
40 lug nuts
Injector cups can, but more often it's cracked heads.
If you're talking about a 6.0, both the injector cup and the low injector o-ring on the same cylinder would have to fail at the same time. Which is unlikely.
yep have the headed submerged and u will find ur problem most causes i find the leak right about the cup its cracked very common, 7.3 liter is the only ones that i get away with only replacing the cups
1 - 8 of 8 Posts
