1 - 3 of 3 Posts
Hello i have a 2008 super duty with a 8inch pro comp lift and i also have 38x15.5r20 toys. The question that i have is I'm thinking of getting a set of 20x14 fuel hostage rims, but was wondering what kind of issues I'm gone run into or rumbaing when turning. Any fed back would be appreciated?
It shouldn't rub too bad I've seen a lot of trucls with that setup
I have 9.5in of lift with 36 15.50 20 with 20x14 wheels it rubs at full lock if I hit a tiny bump but if you trim the plastic on the bottom of the bumper and cut or roll the bottoms of the metal fenders and also the plastic inner fender you will be good to go. Its just not a bolt on and go setup if you want to turn.
1 - 3 of 3 Posts
