1 - 11 of 11 Posts
water in fuel light on, 05 6.0 ex cant find drain valve anywhere on the frame rail fuel filter, any ideas:confused:
Still learning
Drop the filter that should drain the water out. Drain plug should be at the lowest point of the hfcm
i saw a plug but owners manuel showed a slid bar in the side of the hfcm
found out owners manuel is wrong has a 6mm drain plug, local ford dealer drained it for free trying to get my warranty business, and then smashed the passenger side mirror backing it out of the ford dealers bay, so guess im getting a free mirror and maybe a new mechanic we will see how easy they fix it...............:lame:
I
Guest
If you do your own oil changes, drain the seperator at each oil change so the light never comes on. If someone else does it tell them to..
go back to dealer and get new designed drain plug all you need are yur fingers for twenty bucks if you need part number let me know supposed to drain monthly
Discussion Starter #9
cool looking piece gotta get one
1 - 11 of 11 Posts
