1 - 6 of 6 Posts
Peon Extraordinaire
So a fuelab is set for 70 gallons per hour at 70psi. A valve that can flow 6 gallons per minute should not present a restriction correct?
Sam
6 gallons per minute times 60 minutes in an hour= 360 gallons per hour....so correct....wouldn't think it would present a restriction. What side of the pump is it on, suction (i.e. feed side) or post pump side and what pressure?
jrc
Busy Busy
At what pressure can the valve flow 6 gallons per minute?
Peon Extraordinaire
I don't have the pressure that it can flow the 6... It would be on the suction side of the pump. I did the math - just wasn't sure if there is something else to consider...
Sam
Compared to stock tank valve I.D. how much bigger is your new valve?
You should be good to go.....
Peon Extraordinaire
I don't know what the stock valve is... The new one is supposed to be 3/8".
Sam
1 - 6 of 6 Posts
