1 - 7 of 7 Posts
I have a 2010 6.4l and after changing the oil, and fuel filters it drove fine for a day and then the next day it died pulling out of the driveway. I primed it like normal to remove any air and it will start after 20 times of doing that then die in 30 seconds.
I am hoping it is the fuel sending unit in the tank. I got the loan a tool from Orielly but tbh I do not know how to use it and there is no instructions.
Any help would be awesome, I need my truck back asap or figure something else out.
Thanks in advance!
Try removing and reinstalling fuel filters, upper and lower? O rings on the caps seated correctly? And visible leaks?
Ill change both of those out again. No visible leaks that I can see but I will give it a shot.
Thank you for the help! I will let you know after I check them.
Please do! Good luck!
So, I changed them out and that wasn't the issue. The pressure testing tool I used from autozone was not working. Used parts of it to create a way to bleed the air and there was a TON of air in it. Now we are back and running!! Thank you guys for all the help and advice!
Glad to hear it was nothing major! Happy to hear you're up and running!
1 - 7 of 7 Posts
