1 - 8 of 8 Posts
Dennis, Getting ready to order my WVO system, and really want to get the fuel bowl out of there, When I asked them they didnt seem to really know what I was talking about..
So do you know if it will work with the V3 system from Conversion Kits, Bio Diesel Kits | Dino Fuel Alternatives
Do we relocate the filter? and is this intended for the OBS aswell .. ??
Discussion Starter #2
hmm, Maybe I wasn't clear enough ..
does your kit Fuel Bowl Delete Kit work for an OBS?
Do you relocate the filter? or would this be intended for a fuel system with its own filters..?
Also tossed in the V3 system wondering if by chance you knew if it would work together, hope that didn't distract you ;)
I am also very interested in your fuel bowl delete, although it is a bit pricey. Will this work for the old body style powerstrokes 94-97.
I dont see why this kit would be much different than a SD as it uses the same heads only difference being that your also deleting the mechanical pump to a electric fuel pump. But someone please correct me if im wrong there. Anyways with a bowl delete typicaly you will add 2 new filters to the system that ride on the frame rail one pre-pump filter and one post pump filter.
Thanks, Dennis I'd like to hear what you have to say about this if you can get the chance, ill drop you an email incase your not on here much
I got fuel filter sensors leaking and bottom 3/8 short hoses leaking I Really want this thing outta there
Will it still work even though I don't have a 17* hpop and sd reservoir?
Nope, I dont think you need the Pump as much as the Reservoir..
1 - 8 of 8 Posts
