Okay, so do you want something cheap or something that works??? We have done several oil samples on a few different vehicles. One truck a few months ago we did an oil analysis on was a 1999 Ford F-350 with 195951 on the engine and 4320 miles on the oil. The analysis came back and said that the engine was on deaths door. Aluminum (piston wear) was 25ppm and Iron, Block, crank, cam wear) was 91 ppm. The national average for our engines is 2ppm aluminum and 17ppm iron!!!!! so then we changed the oil and installed the FS2500 bypass filter kit w/ stainless braided lines, the customer drove the truck 7255 miles and did another oil analysis, the outcome.........7 ppm aluminum and 58ppm iron. Now, that may still not be down to the national average, but he drove the truck 2935 miles longer with less wear. Also the oil at 7255 miles still carried a TBN of 9.4 Which is pretty darn good considering it starts the test at 12.0. We have just done another sample on the same truck and are awaiting the test results. I will post as soon as I know the results. Just my .02 cents take it or leave it. FWIW we are trying to come up with a product that will do the same thing just a little cheaper. and If you are lucky we might even do a DIY and supply everyone with the part #s so that you can save even more money.
