1 - 9 of 9 Posts
Anyone ever replaced or put new lift leaf springs in the front of their truck? How in the heck do you get the leaf spring bolt out of the passenger side? When I try to take it out, it hits on I believe the core support. Any tricks? I've got a shop manual and its says to just take the bolts out but I don't see how.
I'm not sure what it is but its keeping me from taking that one bolt out.
You can remove cooler or you can cute it and put a new bolt on from the other side when your done
*cut
I was thinking cutting the bolt but wasn't sure. Is that the only ways to do it?
the stryker god
Its not the trans cooler its the bottom mount for the condenser. Takes a second to move it. Easier than cuttin it
Shop manual says detach push pin and remove the bolt and condenser bracket? I'm kinda lost on what to do here.
Discussion Starter #9
Ok guys, got it thanks!
1 - 9 of 9 Posts
