1 - 8 of 8 Posts
would 1977/76 front springs fit in the our OBS!! as a add a leaf!
Discussion Starter · #2 ·
took a closer look at them, and they measure really close to the same mounting points! the old hi-boy has six leafs up front vs. two on the OBS! I'm on the fence on doing the swap!
OBS junkie
It should work fine as long as it's a 3" wide spring & the holes line up. Something to consider though, if your still rocking the TTB you will need drop brackets, & a drop pitman arm.
Discussion Starter · #4 ·
what do u mean by TTB? the OBS is in stock form no mods done too the suspension!
OBS junkie
:whs: If you are still running an independent frontend, I'd forget about lifting it.
Discussion Starter · #7 ·
Im sending it too the local scrap yard very shortly! so its going to stay the way it is! I was thinking that i might be able to use them as helpers! Im just sending it the yard! Im thinking of going with a 4" lift with all the right parts for my truck!
Thanks!!
1 - 8 of 8 Posts
