1 - 2 of 2 Posts
I have a 2001 7.3 that the PCM went out on. Sent it in and got a new one. Got it back, plugged it. Check engine light went off. It’ll crank but no start. Water separator light is on along with battery light. Glow plugs relay seems to be working. Have fuel coming out fuel bowl drain tube when I trip the lever to drain it. Doesn’t smell bad or seem watery. Sprayed some starting fluid in the air filter. Fired but only for a few seconds... any ideas?
Have you checked for pressure at the schrader valve on the drivers side of the fuel/ filter housing. @40- 50 lbs.
Lately I have been following related threads and the fine filter and small orfice within the regulator have been clogged.
keep us informed.
1 - 2 of 2 Posts
