01' 7.3. Bought truck back in nov. With 190 injectors hydra tune, no fuel bowl has mod(driven diesel)
Taking off turbo pipes to check where small oil leak in valley coming from and why white smoke coming from my truck when I got on it on friday but doesn't smoke in idle. Coolant was at level and nothing in it and major oil leaks. I saw oil was on the side of the turbo on/below wastegate and underneath on the pedestal. After several hours(!)
of cursing n walking away from the rear v clamp and finally removing after several UTUBE vids. and making a mini slide hammer with 12" bolt, washer, nut and 1/2 socket cut off wheel(hopefully that can help someone?), removed the turbo and heard something inside and found this?
Time for new turbo, if so suggestions?
It is garret 702720. I looked up says 70mm?
Truck has a hydra tune, does that make difference on which turbo size to get or stay what was with it?
Thanks Tim
Thanks Tim
