1 - 9 of 9 Posts
if the swap has been done well... yes
A 70's model ext. cab 4x4 is hard enough to find, much less with a Cummins.
< YOU WISH...
That's a v-6 industrial engine in that truck...Not a normal 24v inline 6. Not exactly a powerhouse. IIRC about 110hp. was the max they were rated at.
the front end on that truck is not off a 78 it is from before 77 the grill and headlights were diffrent in 77 and 78 could have been changed! 77 and 78 both had square headlights and the grille was a little dif.
Forget it then, i thought it was out of a truck oh well
< YOU WISH...
Nope, old industrial engine with internal fuel lines and injectors fired by the cam. Good engine in 1980's equipment but no easy way to make power over stock.
Power by IH
Its a 78 front end, 77 had the split grille, 78's had the one piece grill and round lights (square headlights were optional in 78, factory in 79).
1 - 9 of 9 Posts
