1 - 7 of 7 Posts
i bought a 01 powerstroke and it said it was faster and it came with a hypertech. well i hooked that hypertech to see if it worked and it gives me a code that says the hypertechscanner can no read the vehicle. so i hooked up my code reader and it reads fine and the code reader throws a code that says its tuned. i cant get the hypertech to read the truck so how do i get it back to stock so i retune it with what i want??
Administrator
If you install a chip it will over ride the tune on the pcm. If it really bugs you. Go to ford and have your pcm flashed.
I would just get a multi position chip. Then you can have a stock calibration and multiple tunes.
should i get the pcm flashed back to stock before getting the chip?
i was goin by a ts 6 postion.
Administrator
No need to. Waste of money.
Administrator
If you ever want to upgrade to bigger injectors get the hydra. If not get the ts6 chip with php tunes from cncfabricationllc.com or ktpreformance.com
1 - 7 of 7 Posts
