Ford F250 / F350 Fog Light LED Bulbs! Several Bulb Model Options! See Comparison Pics & Install! USA Made SLF!
Diode Dynamics carries LED bulbs for replacement of your Ford F-250/F-350 Super Duty's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your F-250/F-350's fog lights a nice bright white that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Ford F-250 / F-350 Super Duty).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 1999-2017 Ford F-250 Super Duty
Diode Dynamics: Fog Light LEDs for 1999-2017 Ford F-350 Super Duty
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Brightness
Bulb Design
Thanks for looking!
Nick C.
