1 - 5 of 5 Posts
do any of you all know if the 450/550s have the same chassis/cab from 99-06? any info would be grrreeat!
i believe so.are you swapping or are you doing something, like installing a different flat,service,or other bed.all ford cab chassis are 34 inch flat rail frames.regular pick up beds do not fit them.
Oooo, White Lightning !
It will fit
I'm wondering about putting an 06 550 bed on a 99 550.
what kind of bed? flat,stake,service,fontaine.
if it measures 34 inches between frame mounting points,it will fit the 550.all cab chassis are made to this spec so you can mount sevice and or other beds,any bed,any cab chassis.same same.
but measure the wheel base carefully,i think there is 3,or 4 different wheel base's for the 450 550.
1 - 5 of 5 Posts
