has any one put a heater on there tranny and if so what kind should i get?
or should i even worry about it!
I know guys that have used magnetic heaters and bought the glue on heating pads. Don't think it makes too much difference.has any one put a heater on there tranny and if so what kind should i get?
Depending on the tranny, the main locations of significant quantities of fluid when shut down are the pan and the torque convertor. At -40, there is some benefit to be derived at startup by warming the ATF to something warmer than -40F. But, the transmission will heat itself up pretty quick. ATF does tend to thicken like any other dino based fluid (unless you are running full syn) at colder temps.
That said, adding a pan heater, while certainly not a BAD idea, is only heating no more than maybe 40% to at most 50% of the fluid.
Is it a bad and/or harmful idea? nope. Will it be beneficial on those cold days at -40 during early warm ups - yes certainly from a performance standpoint, and to a lesser degree from a longevity standpoint. Is the different like to be significant? Probably not as much as you might think.
You will get delayed shifting longer at cold temps while the computer refuses to lock up the TC (a major heat producer unlocked, which is why it is inhibited when cold).
Overall, if you felt inclined, go for it. Mandatory? naw. (my opinion). If I had an easy to apply pan heater handy and was looking at a winter where -40 was common, would I ? Sure.
I do not understand this! I have filled up here in SE Michigan since the truck was originally purchased (March '02) and for the most part have never had to add anything to the fuel to keep it from gelling. Where do you fill up? I want to make sure I never fill up there. I use a major truckstop at the intersection of I-94 and Baker Road just west of Ann Arbor. They go through a ton of fuel so there is no time for it to accumulate water. It apparently is well formulated for our environment. I have seen some crystals of frozen water in the fuel but since installing the Dahl filter at 6000 miles or so, I have never had water make it past the Dahl filter to the filter bowl under the hood.I hope this year my truck will run in the winter without getting gelled fuel. Last year my fuel kept gelling up.....
I have never had fuel gelling problems. With a stock fuel system in good working order and properly blended fuel, neither should you.I hope this year my truck will run in the winter without getting gelled fuel. Last year my fuel kept gelling up.....
I've had bad luck with flying J fuel. Froze up 3 times on me last winter with additive.I do not understand this! I have filled up here in SE Michigan since the truck was originally purchased (March '02) and for the most part have never had to add anything to the fuel to keep it from gelling. Where do you fill up? I want to make sure I never fill up there. I use a major truckstop at the intersection of I-94 and Baker Road just west of Ann Arbor. They go through a ton of fuel so there is no time for it to accumulate water. It apparently is well formulated for our environment. I have seen some crystals of frozen water in the fuel but since installing the Dahl filter at 6000 miles or so, I have never had water make it past the Dahl filter to the filter bowl under the hood.
Find a source that is a high volume diesel fuel retailer in your area. The truck stop I fill up at goes through 9-11 tankers full of fuel a day! Looks like more traffic at the truckstop than O'Hare on a busy day. LOL. I figure the fuel that I fill up with is probably been in the tank less than 3 hours. Some of the small retailers fuel has so much water in it that it will form a suspension of ice crystals and it is these that will plug up the fuel filter. Most anti-gel additives will not do much for ice.I was filling up alot in almont at a small gas station called speedy q. All winter I was also using additives. Then after trying to figure out what the hell kept going wrong, I went to another place to fill up here and never had a problem. I know keep a bottle of diesel 911 and can look at the fuel pressure gauge, and i know when its need some 911.
I had the same as above. I didnt have battery blankets(they do u no good) and no battery heaters( they do u no good either) My truck started everytime it was plugged in. The only time mine didnt start was a couple weeks before i left Eielson when my batteries went bad. Wouldnt even start when plugged in all night. Those orange pad heaters can throw out some serious heat. They work well on the tranny and engine oil pans. For yout batteries, if you wanted to, you could tie in a couple battery trickle chargers, those work wonders. They keep your batteries charged when plugged in. I did that on my Ford Ranger when i moved to Eielson in Alaska and never had a problem. A battery heater pad will keep the battery from freezing, but it doesnt keep it chargedwhen I was up their in ak I used one of the orange battery pads. used rtv and stuck it to the pan. Made a huge diffrence on how fast I could drive away. I had one on the motors oil pan as well. My truck always warmed up faster than everybody elses at -40. But then again on eilison afb they had the plugs all over base so I wasnt paying for 2battery blankets, 2 battery pads, 2 block heaters running. When I was at the house I had a timmer that would start all of them about 2 hours before I had to go to work.
Hummmmmmmm......I didnt have battery blankets(they do u no good) and no battery heaters( they do u no good either)
(snip)
