1 - 4 of 4 Posts
Bulbs are good, fuse is good, indicator light comes on when the switch is pulled. Just no light. 2007 F250 XLT Super Duty extended cab. Anybody else have this problem?
I have this problem as well, They worked halloween night, and haven't since wondering if anyone knows why. I have a 2006 f350 amarillo edition.
i too had this problem and as it turns out it was a bad relay.Unfortunately the relay is built in to the fuse panel and not serviceable.my thinking was that the relay has to do with how it grounds and the high beam circuit etc.what i did is take the yellow wire from behind the fuse panel which activates the fogs and jumper it with an inline fuse to the brown/orange foglamp wire .this truck was a 2006 you can check at your foglights for your wire color and test the at the back of headlight switch to be sure your yellow is power for fogs.
Ok Finally got around to doing this tonight. Works great now Thanks. I happen to like that they work with the brights on as well.
1 - 4 of 4 Posts
